and also, when i try to open the same project in another computer. i find all the prepend path were correctly starting with "@/." and then reference/sublayer node could work. so i was thinking is it something realted to some weird environment Path parameters? any help would be appreeciate!thanks
error: Prepend path in USD file generated in Solaris wrong
553 0 1-
- richardbao
- 8 posts
hey guys, new to USD and solaris. recently following tutorial from houdini. while using Component builder tool. i was trying to build a payload and varient set. i did not modified any of the params that i download from the source. but after save the usd to files. i found all the prepend path were starting with " @_Projects/...", so the usd file cannot resolve it. then i try use a sublayer or reference node to load usd files that has prepend path in it. none of them could work(of course...) and here is the component out settings and error i got from the node.
