Variable for and Ordinal of a Set of Selected Nodes
   560   0   0
Say I have an expression in a parameter field of a set of (n) nodes and I need to set a value in that expression to an integer (e.g. a point number). It's fine if the value (point number) is just an integer from 0 to n-1.
Now, can I select all the nodes (in the network view) and insert some variable that represents the selected nodes, 0-n-1?
In c4d this was possible for any set of selected objects.
Anything similar here in Houdini?
Thanks,
Greg
