Variants from multiple separate USD files
   1014   1   1
Hi.
New to Solaris here. Is there a way to use explore variants node on multiple USD files imported through reference node? How can one make variants from multiple separate USD files? So far I've seen examples with component builder for 3-5 objects. What if there are 50 objects. You import them one by one and set it as a variant? Thank you in advance.
Edited by chabashvili - May 5, 2025 00:58:18
If you want to create many variants, you can use the for each nodes.
https://www.sidefx.com/docs/houdini/nodes/lop/foreach.html [www.sidefx.com]
Edited by Heileif - May 5, 2025 12:29:30
