Waveform Generation in MotionFX for Sequential Blend SOP
   901   2   0
I'm using a Sequential Blend SOP for n parameters. I'd like to create a waveform that steps up smoothly to each parameter 0 - n-1 holding for a bit at each integer value. A rough pic of the kind of waveform I'd want to create below.
Any and all suggestions greatly appreciated!!!
Greg
Screenshot 2025-05-19 at 16.18.41.png (2.5 MB)
Find CHOP drive deform file on Odforce forum or Here on Forum. Use Quantize!
Conservation of Momentum
cncverkstad
I couldn't find either of those references. Could you post a link?
Also, I found a partially procedural solution. I animated a point along that curve above with a Carve SOP (animating the U percent) then used P.y to generate the values 0-2. This is ok-ish except I have to construct the curve differently for the number of variations of an attribute I want to blend. The above curve works for 3 versions of an attribute.
Any ideas for a fully procedural technique?
Greg
