Null Node stops the stream in a MtlX shader
1325 2 1-
- ivYan
- 3 posts
Does anyone know why the null node in a MaterialX subnet or in Karma Material Builder stops the stream at the place it is connected? I thought it's supposed to do nothing and pass anything from its input to its output. It tried both in Karma CPU and XPU. I am attaching screenshots with a simple example. Thanks.
Edited by ivYan - May 31, 2025 07:39:47
- rafal
- 1471 posts
- ivYan
- 3 posts
rafal
Not supporting Null VOP fully is a bug (117527 & 145190). IIRC the main obstacle is that null allows renaming ports (variables) in the generated source, so would probably need to be translated into a bunch of Mtlx Dot shaders. Or just keep it simple and flow thru without ability to rename anything.
Thank you for the response!
