How Switch reads value from ForEachPoint?
   891   2   0
My question:
how can I read the value of "iteration" from ForEachPoint node?
for example,
I have 3 different objs connected by Switch node
I want each them to be copied using ForEachPoint node
By expression
detail("../block_begin1", "iteration", 0)
I get Wrong results,which all are 0:
It is supposed to be:
So coming to my question
Thanks for help in advance!
Official Documents Ref:
https://www.sidefx.com/docs/houdini/model/looping.html [www.sidefx.com]
Switch with CopyToPoint.hip (87.4 KB)
The Block Begin node has a button to create another Begin node set to Fetch Metadata. Plug that as a spare input and pull the attribute value with
detail(-1, "iteration", 0)
Edited by Fenolis - June 7, 2025 11:23:44
Fenolis
The Block Begin node has a button to create another Begin node set to Fetch Metadata....
Oh, thanks ,Fenolis~
You reminded me that
Only to create another Begin node brings in the attributes "iteration"
Thanks a lot!
