dy Install Libs is a Houdini shelf toolset designed to make installing libraries smooth and simple. No manual edits, no broken installs.
What’s Inside:
- Library from JSON: Import a downloaded library using its JSON file—automatically copies and updates the package file in your library folder.
- Install Library: Generate a new JSON package from scratch, tied to your library folder.
- Library from GitHub: Clone and install libraries straight from a GitHub URL.
- Create Library: Build a library scaffold with templates and auto-generate the package file.
- Restart Houdini: Reload everything easily with one click.
You can get it here: Gumroad [cdordelly.gumroad.com]
Check the Product Website [cdordelly.notion.site]
This may not work for installing render engines, as they typically need a custom .json package file to set up environment variables and paths.
✅ Why You'll Love It:
- Save time – eliminate manual file edits and avoid broken setups.
- Stay organized – manage local and GitHub libraries seamlessly.
🌟 Get It Free!
Download this tool at no cost. If this product makes your work easier, your support is greatly appreciated ♥
dy Install Libs
1861 3 1-
- cdordelly
- 209 posts
Edited by cdordelly - July 7, 2025 18:52:37
- cdordelly
- 209 posts
Hey guys! I want to share a new release from dy Install Libs 1.1
Now you will be able to install GitHub Repositories Releases very easily! It simplifies library installation with just a few clicks, making it ideal for installing multiple libraries.
You can download it here: https://cdordelly.gumroad.com/l/dy_install_libs [cdordelly.gumroad.com]
v1.1 (2025.8.5):
Hope it saves you time! Enjoy!
v1.1 (2025.8.5):
- Library from GitHub: Support for download GitHub Repository Releases.
- Library from GitHub: fixed and replaced old "path" JSON variable for "hpath" where a GitHub repo doesn't have a package file.
- Installed Package File: Support for relative paths using $HOUDINI_PACKAGE_PATH variable.
- cdordelly
- 209 posts
Hi guys! I want to share a new release from dy Install Libs 1.2
v1.2 (2026.2.25):
v1.2 (2026.2.25):
- Copy Preferences: Copy current (or custom path) Houdini preferences into a new location.
- Copy Preferences: Custom user selection of files and directories to be copied.
- cdordelly
- 209 posts
Hey guys! I want to share the biggest dy Install Libs release so far — v1.3 🥳
This release comes with a brand new tool called Library Manager, a combination and evolution of all previous toolkit tools, now unified into a single custom UI packed with awesome new features.
v1.3 (2026.3.24):
Hope it saves you some headaches! Enjoy!
v1.3 (2026.3.24):
- Download, install, enable and disable your libraries from a single UI.
- Browse a library database with favorites and custom tags.
- Quick access to commercial library websites (MOPs+, Axiom, etc).
- Install directly from GitHub URLs or JSON files.
