Is Connected VOP
   1319   6   1
I'm trying to use the Is Connected VOP for the first time.
I'm in a subnet ( ultimately to become an HDA ), and I want it to output one color ( red ) if an input is not connected, otherwise output the connected input ( green ). The way I have it set up, it's outputting the expected color when the input is connected, but not when not connected ( it's outputting black instead of red ). So, is this not the way it's meant to be used?
Please see the attached hip file.
Edited by A-OC - Aug. 28, 2025 01:53:38
is_conn.hip (688.6 KB)
while Is Connected VOP doesnt seem to work, you don't really need it
- just create your HDA and then set default value to your promoted custom_input parm and if you don't want to see it in UI make it invisible
- or alternatively use Parameter VOP set to Subnet Input using the same idea
is_conn_mod.hipnc (691.6 KB)
Thank you, the problem is that my actual need is to use "Position" instead of color, that was just the simplest scene possible, I guess it was too simple then.
So, what I really need is to output the connected position ( when it is connected ), otherwise output uvs ( from UV Position node )
so it looks like Is COnnected only woks with Subnet Inputs node, which seems to be hidden
not with the default Subnet Input Connector node, and it's probably a bug
have a look at the attached example using Subnet Inputs
is_conn_mod2.hipnc (686.0 KB)
Interesting. I'm trying to recreate it but it's not working for me: I connect P to null_1, then that to null_2, then make a subnet out of null_1, inside there is the Subnet Inputs node, then build the logic there. When done, if I disconnect P outside I get an error, so I guess it only works with hda's. So I create an hda, then test again, but when I disconnect P I get black as output again. What did I do differently?
A-OC
hard to tell, but try plugging your result into next output, not the same name as our input, I'm also getting black if I use the same name
Amazing, that's it. Thanks a lot once again.
