When I import camera via LOP the image rendered is blury
   370   1   1
Hello all,
I have animated camera that I would like to import in LOP network - lopnet1.
When I use Scene Import (All) node I am able to import the scene and see the camera that I need:'MAIN_ANIMATION_CAMERA'.
When I use Karma (Setup) node to set Karma, everything seems to be normal. From 'karmarendersettings' I am able to choose the imported camera. The problem occurs when I render image in 'usdrender_rop1' it is blurry.
I was not able to find any way to fix that! Please note that if I create new camera in the LOP network, the rendered image is perfectly sharp.
How can I import my animated camera and render the scene in Karma without producing blurry images?
Check your depth of field, you may have your camera distance focus in the camera a bit off, I don't know what you mean about the karma set up, but I think the karma node has dof on by default, and maybe if you are previewing before that is off, so you could and an editCamera to adjust your focus distance in lops, or disable the option in the karma node
