I have an ocean spectrum and ocean evaluate node.
I want to pin a small boat model to it and have set-up a ray sop for this so it moves with the waves (geo) It’s working but it’s obviously very erratic as the waves on the oceanspectrum are choppy.
Can anyone give me advice on a set-up to average out the position and rotation of the boat. To smooth it out. (After the ray sop node)
I’ve tried attribute blur but it doesn’t seem to smooth it out. The orientation is the main issue. The normal is obviously jittering around a lot. I just want to smooth this out.
I have a single point extracted from the boat model > raysop and I’m copying my boat model back onto that deformed point.
Any help would be great.
Average out a RaySOP position and normal (smooth it) -
561 2 1-
- br-ez
- 1 posts
- lucap1
- 33 posts
You could scatter points on a circle and ray those points onto your ocean evaluate. Then you could use an attribute promote to get the averaged normal. This is convenient because you can scale the circle up or down depending on how smooth you want it. Additionally you can smooth out you normal over time using chops
- rafaels
- 702 posts
I usually bring the position information into CHOPs and filter it out. I also like to add some lag and jiggle to it for extra fun...
Cheers
Cheers
Toronto - ON
