File node not showing in the Renderview
347
2
2
- iso
- 28 posts
This is a simple test to see how an imported OBJ renders in Houdini
The Loop GEO contains the file node. The ball GEO contains Houdini's standard sphere
As you can see, the renderview does not see the object, but it does recognise houdini's sphere.
What setting do I need to add/change so the renderview shows the file node containing the link to the object?
Edited by iso - Jan. 15, 2026 13:58:53
File node.jpg (683.4 KB)
- Tanto
- 546 posts
I do faintly see the object in your render view.
- iso
- 28 posts
Tanto
Thanks. I resolved it by adding a material node after the file node.
Edited by iso - Jan. 16, 2026 08:56:07
