Crash on Startup on VDI machine
   301   2   0
Hello:
I have a Windows 11 VDI machine trying to run Houdini 21.0.596 which crashes shortly after showing the splash screen. Unfortunately, I don't a crash log in my houdini_temp folder so I can't paste that here.
Running hgpuinfo -q I don't get a successful return:
C:\Program Files\Side Effects Software\Houdini 21.0.596\bin>hgpuinfo.exe -q
C:\Program Files\Side Effects Software\Houdini 21.0.596\bin>echo %ERRORLEVEL%
-1073740791
And in the event viewer I get:
Faulting application name: houdini.exe, version: 21.0.0.596, time stamp: 0x6968816c
Faulting module name: KERNELBASE.dll, version: 10.0.26100.7824, time stamp: 0xad803701
Exception code: 0xe06d7363
Fault offset: 0x00000000000ca80a
Faulting process id: 0x3818
Faulting application start time: 0x1DCA5B803BEEA30
Faulting application path: C:\Program Files\Side Effects Software\Houdini 21.0.596\bin\houdini.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: 5dc4a020-6582-4bdb-9daf-c0d7c947eabc
Faulting package full name:
Faulting package-relative application ID:
nvidia-smi returns:
NVIDIA-SMI 582.16 Driver Version: 582.16 CUDA Version: 13.0 |
Is there a workaround or maybe a known error for using a VDI machine with grid drivers? Thank you!
Edited by blaven - Feb. 24, 2026 13:13:00
Thanks! Looks like setting HOUDINI_USE_HFS_OCL=0 (and killing a zombie houdini.exe process) did the trick.
I do get a warning when houdini starts though:
OpenCL Exception: (-33)
Generating new icons...
Done generating new icons.
(Anything I should worry about?)
Thanks again!
