APEX | SceneAnimate <Mirror Pose
   445   2   1
i have some trouble to get the scene_animate mirror tool to work. I attached a clip from the behavior.
how do I have to setup up the controls so they can be mirrored correct? right now they switch places
I first thought it failed cause I put the controls inside subnets, but I tried several different methods, but with no effect.
naming conventions (L_*, R_*)seems to be ok but, who am I to say :/ . at least I found not yet where to adjust.
I attached the test file as well if someone wants to have a quick look
thank You for Your time
Martin
Edited by sanostol - Feb. 25, 2026 13:26:43
apex_mirror_ctrls.hipnc (694.8 KB)
2026-02-25 10-43-00.mp4 (9.7 MB)
For the mirroring to work you will need to give apex an idea of how the mirroring is supposed to work.
Add a configure character on the character stream, toggle mirroring on and set the left token to "L_" and right token to "R_".
Now it will know what to do with the controls and should works as expected.
Great, thank You
