I was wondering if there was a way to have what is visibly displayed in the viewport show something different from what is actually being output? Maybe there's a way to do it through the viewer state? Though typically that's more an overlay so not sure if it's capable of overriding the node output view.
I could set the output to be invisible and add what I want to show as the Guide Geometry but that is not ideal at all.
(SOLVED) HDA Display one thing but Output something else?
317 2 3-
- JohnDoe777
- 48 posts
- vikus
- 254 posts
You can access the scene viewer and pass geo through drawables: hou.SimpleDrawable [www.sidefx.com]
For interactive stuff same principles with viewer states; for simple wireframe hdas guide geo.
Edited by vikus - March 18, 2026 11:25:24
- Liesbeth_Levick
- 82 posts
If you don't want your actual output to display at all, then create an output with the index -1, and then in your viewer state script you can use
You can take a look at the Otis Muscle and Tissue Configure state to see options for having the alternative output always display, or only display when you're in the viewer state.
node.setOutputForViewFlag(-1)
Liesbeth Levick
Technical Director: CFX
