How to use divergence on pyro cops?
   441   5   1
What is the proper way to use the divergence field inside the Pyro COPS workflow?
If I try to plug anything on the divergence output nothing happens.
Any tips?
Edited by mzigaib - March 20, 2026 18:18:22
https://vimeo.com/user2163076 [vimeo.com]
I mean this input here.
Edited by mzigaib - March 21, 2026 01:35:43
No tips?
I am trying this, divergence does not affect anything.
Edited by mzigaib - April 2, 2026 11:23:50
It does work, maybe bump up the values a bit to see
your setup applies divergence only in source area, but you can also test on different setups, like a simple setup where you feed the simulated temperature (scaled as needed) to divergence to get it expanding in hot areas etc...
You are absolutely right! The thing is that I was expecting that it would work exactly like pyro SOP which I use all the time but in this case I forgot to increase the divergence value a bit.
Thanks for the help.
