Houdini 21.0.631 on CachyOS
   355   1   0
Hello guys!
(Hopefully) There are probably some people that are using CachyOS as well, I have installed Houdini 21.0.631 using the launcher, when I am trying to launch Houdini, it crashes after a few seconds during splash screen loading.
Here is the information from the crash log error:
Crash report from b329d3e7; Houdini FX Version 21.0.631 [linux-x86_64-gcc11.2] Uptime 11 seconds Sat Mar 21 16:00:31 2026 Caught signal 11 Traceback from 5906 ThreadId=0x7f2d8c8d4400 AP_Interface::coreDumpChaser(UTsignalHandlerArg) <libHoudiniUI.so> AP_Interface::si_CrashHandler::chaser(UTsignalHandlerArg) <libHoudiniUI.so> signalCallback(UTsignalHandlerArg) <libHoudiniUT.so> UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so> UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so> __sigaction <libc.so.6> [0x546bf] <libGLX_nvidia.so.0> _nv019glcore <libnvidia-glcore.so.580.142> _nv008glcore <libnvidia-glcore.so.580.142> clGetExtensionFunctionAddress <libnvidia-opencl.so.1> clGetGLContextInfoKHR <libOpenCL.so.1> CE_Context::getContext(bool, bool) [clone .localalias] <libHoudiniUT.so> RE_Visual::createSharedGLWidget_() <libHoudiniUI.so> RE_Visual::RE_Visual(RE_DisplayMode) <libHoudiniUI.so> RE_OGLRender::getVisualForMode(RE_DisplayMode) <libHoudiniUI.so> UI_QtWindow::doOpen() <libHoudiniUI.so> UI_Queue::processNextEvent() <libHoudiniUI.so> UI_Queue::drain() <libHoudiniUI.so> UI_Queue::drainEvents(bool, bool) <libHoudiniUI.so> OPUI_MainApp::onUiCreated(UI_Event*) <libHoudiniAPPS2.so> UI_Queue::processNextEvent() <libHoudiniUI.so> UI_Queue::drain() <libHoudiniUI.so> UI_Queue::eventLoop() <libHoudiniUI.so> main <libHoudiniUI.so> __libc_init_first <libc.so.6> __libc_start_main <libc.so.6> std::__throw_bad_array_new_length() <houdini-bin>
I noticed that I was able to launch it, if I specify houdini to use the CPU integrated graphics, but the idea is actually to use my nvidia one.
I have tried to make sure that I have the correct nvidia packages installed, and it seems so.
Anyone else had or is having similar issue?
NVIDIA-SMI 580.142
Driver Version: 580.142
CUDA Version: 13.0
current kernel version: 6.19.9-1-cachyos
Some users have reported their findings of CachyOS here [www.sidefx.com]. However, please note that it isn't a supported operating system [www.sidefx.com].
