Registration key seem's dont work with linux mandrake 8.2, after read the
forum and changed my shell to csh and domain/host to newhost.newdomain ( No
ethernet card ).
When i install sesi the teminal say:
—– SERVER newhost.newdomain ——–
SERVER newhost.newdomain 00000000
Current License Status:
*** WARNING *** - No valid server lines found
Please install licenses using the Houdini License Administrator
(hkey). Start hkey by first changing to the directory where
houdini is installed and then running:
source houdini_setup
hkey
License tools have now been installed.
After start sesinetd /var/log/sesinetd.log say:
07:31:27 09/21/02 sesid: server shutdown pid=3479
07:31:48 09/21/02 sesid: server start pid=3849 IP: 127.0.0.1
07:31:48 09/21/02 sesid: Usage: 0/0/0 Houdini/NonGraphic/Render
07:31:48 09/21/02 sesid: QueueStats: 0 requests 0/0 peak/fail
07:31:48 09/21/02 sesid: Threads: 1 peak, wait: 1e-06/1e-06
07:31:48 09/21/02 sesid: Max Wait: 0 (0/0)
07:31:48 09/21/02 sesid: Avg Wait: 0 (0/0)
When i run hkey the terminal say:
The Houdini environment has been initialized.
Loading required GL library /usr/X11R6/lib/libGL.so.1.2
And a splendid core is dumped with a new file sesi_licenses.pref wich contain:
serverhost=newhost.newdomain
A part of the core file ( 2.6Mo ) say:
0000:2010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …………….
0000:2020 57 41 52 4e 49 4e 47 3a 20 41 6e 20 6f 6c 64 20 WARNING: An old
0000:2030 76 65 72 73 69 6f 6e 20 6f 66 20 74 68 65 20 6c version of the l
0000:2040 69 63 65 6e 73 65 20 73 65 72 76 65 72 20 28 00 icense server (.
0000:2050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …………….
0000:2060 2e 20 20 54 6f 20 62 65 20 61 62 6c 65 20 74 6f . To be able to
0000:2070 20 69 6e 73 74 61 6c 6c 20 61 6e 64 20 72 65 74 install and ret
0000:2080 75 72 6e 20 6c 69 63 65 6e 73 65 73 20 73 75 63 urn licenses suc
0000:2090 63 65 73 73 66 75 6c 6c 79 2c 20 70 6c 65 61 73 cessfully, pleas
0000:20a0 65 0a 75 70 67 72 61 64 65 20 74 68 65 20 6c 69 e.upgrade the li
0000:20b0 63 65 6e 73 65 20 73 65 72 76 65 72 20 74 6f 20 cense server to
0000:20c0 76 65 72 73 69 6f 6e 20 35 2e 35 2e 33 36 20 6e version 5.5.36 n
0000:20d0 6f 77 2e 00 00 00 00 00 00 00 00 00 00 00 00 00 ow…………..
0000:20e0 54 68 65 20 66 6f 6c 6c 6f 77 69 6e 67 20 6d 61 The following ma
0000:20f0 63 68 69 6e 65 73 20 61 72 65 20 75 73 69 6e 67 chines are using
0000:2100 20 74 68 69 73 20 6c 69 63 65 6e 73 65 3a 00 00 this license:..
0000:2110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …………….
0000:2120 59 6f 75 20 64 69 64 20 6e 6f 74 20 63 68 6f 6f You did not choo
0000:2130 73 65 20 61 6e 79 20 6b 65 79 73 20 74 6f 20 69 se any keys to i
0000:2140 6e 73 74 61 6c 6c 2e 00 00 00 00 00 00 00 00 00 nstall……….
0000:2150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …………….
0000:2160 63 6f 6e 66 69 72 6d 5f 72 65 74 75 72 6e 5f 6c confirm_return_l
0000:2170 69 63 65 6e 73 65 5f 6d 65 73 73 61 67 65 00 00 icense_message..
0000:2180 41 72 65 20 79 6f 75 20 73 75 72 65 20 79 6f 75 Are you sure you
0000:2190 20 77 61 6e 74 20 74 6f 20 72 65 74 75 72 6e 20 want to return
0000:21a0 74 68 69 73 20 6c 69 63 65 6e 73 65 20 74 6f 20 this license to
0000:21b0 53 69 64 65 20 45 66 66 65 63 74 73 20 53 6f 66 Side Effects Sof
0000:21c0 74 77 61 72 65 3f 0a 41 6e 20 61 63 74 69 76 65 tware?.An active
0000:21d0 20 69 6e 74 65 72 6e 65 74 20 63 6f 6e 6e 65 63 internet connec
0000:21e0 74 69 6f 6e 20 69 73 20 72 65 71 75 69 72 65 64 tion is required
0000:21f0 2e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …………….
0000:2200 59 6f 75 20 61 72 65 20 6e 6f 74 20 63 75 72 72 You are not curr
0000:2210 65 6e 74 6c 79 20 65 6e 74 69 74 6c 65 64 20 74 ently entitled t
0000:2220 6f 20 61 6e 79 20 6c 69 63 65 6e 73 65 73 2e 00 o any licenses..
0000:2230 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …………….
0000:2240 0a 28 54 68 69 73 20 65 72 72 6f 72 20 6f 63 63 .(This error occ
0000:2250 75 72 72 65 64 20 77 68 69 6c 65 20 6c 6f 61 64 urred while load
0000:2260 69 6e 67 20 74 68 65 20 70 72 65 66 65 72 65 6e ing the preferen
0000:2270 63 65 73 20 66 69 6c 65 2e 29 00 00 00 00 00 00 ces file.)……
0000:2280 4e 6f 20 70 72 6f 78 79 20 70 6f 72 74 20 6e 75 No proxy port nu
0000:2290 6d 62 65 72 20 69 73 20 73 70 65 63 69 66 69 65 mber is specifie
0000:22a0 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 d……………
I've run the sesinetd -v and the version is good. ( 5.5.36 )
sesidctrl -n return:
The server code for “newhost.newdomain” is:
# ./sesictrl -n
sesictrl -i Return
I dont need Red Hat, I don't need ethernet card.
What can i do?
Thank's.
Resgistration problem with mandrake 8.2
7513 1 0-
- M-M
- 1 posts
- stevenong
- 1634 posts
Unfortunately, an ethernet card is required. Please go to the following link for more information.
http://www.sidefx.com/forum/viewtopic.php?t=34 [sidefx.com]
Cheers!
steven
Cheers!
steven
