motion blur on fur
   3594   2   1
what is the approach to motion blur fur ?
I tried velocity blur with no luck ..
lulu116
Motion blur should work the same for fur as it does with anything else in Houdini.
When using velocity blur, you must remember to turn on the “Geometry Velocity Blur” checkbox on the object (Render tab> Sampling sub-tab), in addition to the “Allow Motion Blur” checkbox on the mantra output driver (Properties tab> Sampling sub-tab).
thanks debbie , I got it now.
I was working with a sequence of disk object and I forgot to put a timeblend sop.
