How to Render Smoke And Fire
   7331   2   2
Hi……..
I tested the Houdini 9 Fluid and smoke Solver and it looks awesome.
But I couldn't figure out how to render the stuff like smoke and fire. When I create the fire or smoke from the shelf, it creates fire and smoke shader inside shops. But those default shaders don't have enough control. I added a spotlight and enabled the raytrace shadows.
But it doesn't look like a smoke. I couldn't find any tutorials. When they are coming ???
Can anyone provide example file for this.
Waiting for ur response.
iamjaideep80 (Jaideep Khadilkar)
Check out this thread:
http://forums.odforce.net/index.php?showtopic=6027 [forums.odforce.net]
There are some hip files with realistic flames. You can probably check out how they were rendered in the file.
did you render out the geo sequence prior to rendering, You also might want to use Deep shadows with smoke
