How can i translate points along their normals but per point transform; i tried with the peak node but it doesnt work with the $PT local variable, how can i transform each point but relative to his normal?, not to the world space like the point sop does.
Thanks.
sorry if all my questions are boring, but you guys are the only people who can help me to understand to release the true power of houdini.
thanks.
Translate points along their Normals Per point
15684 8 2-
- Alejandro Echeverry
- 691 posts
- kuba
- 345 posts
- 691 posts
Thanks Cuba, but how can i control the translation of each point, like the point sop does with the local variable $PT, but with the peak sop.
is that possible?
is that possible?
- kuba
- 345 posts
- 691 posts
Yes i can work with these expressions, but the real problem is that the peak sop can´t work per point like point sop does; how can i do that type of transform per point along their respective normal;
for example i would like to put a sine wave along the points for a tentacle movement, but i want that the sine wave affect only the ty component and translate each point relative to the normal orientation, not the world space, like point sop does.
how can i do that?
how can i do that?
- graham
- 1926 posts
You can use a Vop Sop to deform the points along the normals and whatever else you'd like.
In the attached file, there is a Peak Sop and beside it is a Vop Sop that does the exact same thing the peak does. However now, you can use the greatness that is Vops to change it around any way you want.
- 691 posts
Thaaaaaaaaaannnnnnnnnnnnkkkkkkkssssssssssss!!!!
My tentacle is correctly alive……
Many Many Thanks grahamm.
- koen
- 795 posts
- Allegro
- 696 posts
