Create curve from points?
   5749   2   1
Is there a way to create a curve from a bunch of points?
I've used the add SOP to place down a series of points and animated them with some expressions. Now I want a curve from those points. I thought the fit SOP was supposed to do this, but I can't get it to work :?
fitTest.hipnc (39.0 KB)
In your Add sop, switch to the Polygon folder and select “By Group”, and the points will be connected, in order by default.
“everything is coincident”
Doh!! - Easy when you know how :roll:
