I have 10 box_objects in my scene. I'd like to get them as a list in python.
I know how to get a list of parameters of a node, but I would like to know how to get a list of nodes matching a name-string.
Something like (this is totally wrong pseudo-code but this is the general idea):
nodeorigin = hou.node('/obj')
boxlist =
found this in the help… not exactly what I need but we're getting closer…
for n in hou.node(“/obj”).children():
print n.name()
I need this to be a list, and take out all objects without “box_object*” in the name…
getting a wild card matched list of nodes with python
8918 6 1-
- josh3light
- 120 posts
- graham
- 1926 posts
- josh3light
- 120 posts
Thanks graham, that's awesome. Now I'm trying to accomplish the next part of the task… I've got this so far:
>>> boxes =
>>> boxes
[<hou.ObjNode of type geo at /obj/box_object1>,
<hou.ObjNode of type geo at /obj/box_object2>,
<hou.ObjNode of type geo at /obj/box_object3>,
<hou.ObjNode of type geo at /obj/box_object4>
I would like to set, for example, the tx of all nodes in the list to 1.
(Here I tried to set all parms to 1 just to try, but I'd really just like to affect one or more parameters at a time)
>>> for theparm in boxes.parms():
… theparm.set(1)
File “<console>”, line 1, in <module>
AttributeError: ‘list’ object has no attribute ‘parms’
I am thinking I might need to use nested for loops here but can't quite get my head around the syntax yet…
>>> boxes =
>>> boxes
… theparm.set(1)
- graham
- 1926 posts
To set tx to 1 on each box:
for box in boxes:
box.parm('tx').set(1)
To set all parms to 1:
for box in boxes:
for parm in box.parms():
parm.set(1)
Here's some other, more advanced ones.
Set multiple parms to the same value:
parms = ('tx', ‘ry’, ‘sz’)
value = 4
for box in boxes:
for parmname in parms:
box.parm(parmname),set(value)
Setting multiple parts with unique values:
parmdict = { ‘tx’: 4,
‘ry’: 50,
‘sz’: 2 }
for box in boxes:
for key in parmdict:
box.parm(key),set(parmdict.get(key)
Setting groups of parms with a similar value:
valdict = {5: ('tx', ‘rx’, ‘sx’),
7: ('ty', ‘ry’, ‘sy’),
19: ('tz', ‘rz’, ‘sz’),
for box in boxes:
for key in valdict:
for parm in valdict.get(key)
box.parm(parm).set(key)
for box in boxes:
for box in boxes:
parm.set(1)
value = 4
for box in boxes:
‘ry’: 50,
‘sz’: 2 }
for box in boxes:
for box in boxes:
for key in valdict:
- josh3light
- 120 posts
- IndyZoneCo
- 77 posts
Use:
hou.node(“/path/to/your/node”).setCurrent(1,1)
to select the target node and deselect everything else that is already selected.
hou.node(“/path/to/your/node”).setCurrent(1,0)
to select the target node while keeping the current selection.
Assuming your Houdini doc server is using the default port, go to:
http://localhost:48626/hom/hou/Node [localhost]
and search for setCurrent() for more details.
- josh3light
- 120 posts
