I am starting with Houdini, could smb. help me how to use c shell under windows ?
I started cmd.exe and in shell I typed csh and got c shell prompt (%)….
But how to use any script ?
I downloaded a script to automate creating shader process called mshop and in the usage I found "mshop shader.sl "…
Then I copied all script in clipboard and pasted it to cshell but I got a lot of errors and I was back to dos.
I also tried with basic render script from tutorial guide with no success…
Could smb. provide step by step instructions ?
thanks in advance…
csh and windows ?
4939 1 0-
- dsinisa
- 2 posts
- Xiangbiao
- 27 posts
The following is fetched from the standard Houdini directory containing
scripts, $HFS/houdini/scripts
You can type some command in .txt file, then save it as FILENAME.cmd in
this folder.
Run hscript, source_FILENAME.cmd,
then the script can been driven.
If what you are talking about are scripts created in TCL, TK or Python.
Very sorry, I'm poor about them.
Hope this is helpful.
this folder.
