Hey all,
I'm exporting some geo from Houdini using FBX and am running into something odd.
When I export my geo through the menu (file>export) it renders out fine.
When I export it using a filmBOX node in a ROP it renders out triangulated.
Anyone know what the difference between the two is?
I'm running 9.5.379.
I've tried replicating the problem on basic geometry but havn't had any sucess in repeating the problem.
Wanted to check here before I delve deeper into the specifics of my setup.
Pav
FBX out through menu VS FBX out through ROP
4104 4 2-
- pgrochola
- 36 posts
- oleg
- 350 posts
There should be no difference between these two methods. Internally, they all go through exactly the same code, it's just the UI wrappers that are different.
It could be a bug, or it could be a difference in settings between the UI and the ROP node. In general, the exporter will triangulate things when it encounters an animated object that has particles, changing number of vertices over the animated period, or any primitive types which the exporter doesn't support directly.
If the settings are exactly the same in both cases, could you attach a file which demonstrates the problem so I could take a look at it?
Oleg Samus
Software Developer
Side Effects Software Inc.
Software Developer
- pgrochola
- 36 posts
- oleg
- 350 posts
Very interesting. I can't reproduce this - exporting through the UI and exporting through the ROP produces identical files, both animated and single-frame. I've tested both importing them back and even running a diff on the ASCII versions, and they are identical, as I would expect.
Which version of Houdini are you running? And on which OS?
Oleg Samus
Software Developer
Software Developer
- pgrochola
- 36 posts
