Creating i3ds clouds
   4111   1   0
Hello all houdini brainiacs.
I've been following along the ‘Creating clouds using i3ds’
http://localhost:48626/howto/clouds [localhost]
In the 3D Texture Generator node i've been trying to point the SHOP parameter to a metacloud shader. I can't directly choose the metacloud shader in Choose Operator. When I write in the shader path I get an ‘No Op Found’ error.
I'm on 9.5.379 / Mac OS X
Wondering if this is a bug. Any one else had similar problems? Or know of a solution.. Cheers, Alex
worked fine for me
this file was built step by step from the help (H9.1.321)
I didn't test the rendering but I was able to build and hook everything up
HTH
i3dsCloud.0.hip (213.8 KB)
Training Lead
www.sidefx.com
