I'm sure that there are several ways of making tire treads on a 3d tire. But other than extruding faces of the grid/mesh to make tire treads, I wanted to know of some other ways that people are using. For example, if i wanted to make a squiggly line or text as the tire tread. is there a way of writing the text, or drawing a line, then sticking it onto the part of the tire that the tread should be on, then extruding that?
I'm guessing if i get the text onto the tire somehow, then extrude the text, i'd have to use a boolean operation at some point.
Anyhow, if anybody would like to share their tire tread making ideas, please do!
different ways of making tire treads
5308 5 0-
- fai
- 35 posts
- gwader
- 40 posts
- fai
- 35 posts
i've been trying to find that elusive trace sop. i'm using houdini apprentice 64bit and i still can't find it! Well i guess that's why i'm an apprentice.
lets say i find the trace sop. i'll trace an image, extrude it…
and then do i bend that extrusion around the tire by eyeballing it, or is there a magic way of using another sop? thanks in advance!
- stevenong
- 1634 posts
- gwader
- 40 posts
- fai
- 35 posts
ok i finally found the trace sop. Thanks for the thread about the Bend SOP. I've downloaded it and installed it (along with a few more sops from that site).
What a coincidence, in that other thread, somebody was trying to bend an object around to make a tire for the Kenada motorcycle from Akira. I was trying to do almost the exact same thing!!!!!
