i have two polygon curves as perpendicular cross sections of a floor shape. i copied cross section one to create two rails on which to apply the second cross section to with the rails sop but it errors out saying “please use atleast two rails.”
:sigh:
can you not use two curves as perpendicular cross sections?
rails? sweep? skin? all error out
5000 4 0-
- sagramor
- 7 posts
- Simon
- 2199 posts
- sagramor
- 7 posts
- stevenong
- 1634 posts
The inputs to the Rails SOP were reversed. All you have to do is to select the Rails SOP & type ‘r’ to swap the inputs.
To see what the inputs expect, you can Middle Mouse click on input connector. Also, the Rails SOP help lists the Inputs information too. The ‘?’ button in the parameters of the Rails SOP will bring up the help card.
Cheers!
steven
Cheers!
steven
- sagramor
- 7 posts
