-Will there be a software update for the latest non-commercial release? Just a few issues.
-Understandably not really supported, but I am unable to bring in HoCommercial 4.1 files without lists of errors, but quite cool that we are able to bring commercial files into HoNC to play or practise with. Some errors are understandable as file locations no longer exist but others are odd with interface elements missing.
-Also noticed with just a plain startup of HoNC that interface elements in parameter view are missing and get list of errors.
For eg. when opening HoNC freash and then selecting camera or with drop down menu trying to view parameters from it I get the following errors listed along with the corresponding GUI elements missing:
/DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 200
ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 206ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 212ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 218ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 224ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 230ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 236ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 242ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 248ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 254ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 258ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 264ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 285ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 315ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 361ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 417ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 435ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 441ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 447ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 461ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 462ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 467ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 484ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 485ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 493ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 495ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 496ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Syntax error on line 497ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 546): Variable “filesize.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 554): Variable “copframe.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 595): Variable “t.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 596): Variable “r.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 597): Variable “s.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 598): Variable “p.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 599): Variable “scale.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 603): Variable “roll.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 604): Variable “pos.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 605): Variable “pathorient.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 606): Variable “up.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 607): Variable “bank.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 614): Variable “orthowidth.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 615): Variable “res.join” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 616): Variable “aspect.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 617): Variable “focal.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 618): Variable “aperture.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 619): Variable “shutter.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 620): Variable “near.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 621): Variable “far.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 622): Variable “focus.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 623): Variable “fstop.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 624): Variable “curvature.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 630): Variable “cropl.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 631): Variable “cropr.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 632): Variable “cropb.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 633): Variable “cropt.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 634): Variable “win.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 635): Variable “winsize.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 636): Variable “winroll.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 651): Variable “display.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 671): Variable “clear.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 673): Variable “fogdensity.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 674): Variable “fognear.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 675): Variable “fogfar.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 676): Variable “fogcolor.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 677): Variable “fogalpha.gad” not defined.ERROR: C
DOCUME~1/GRAHAM~1/LOCALS~1/Temp/houdini5.5/config/Dialogs/OBJ5.5.36/cam: Error (Line 684): Variable “dcolor.gad” not defined.
ops: Note to self:
