SWEEP NODE PROBLEM????????????????
   7929   6   0
Hi! I made a road using sweep node, but when I tried to transform my curve,
this road began twist around this curve. So, how can I do this road, along all lenght of the curve, always be 90 degrees to Y axis (pic.1)?????????
if the street is only on ground level with no mountains, you can scale the street in Y, or you use a ray-sop to project it onto a grid. generating normals (for the curve) pointing to Y may help as well.
cheers Seb
caps and hundrets of ?, do not help solving your problem faster!
Thx Seb! Ok I ganerated normals from points, so how to change direction of normals to be 90 degrees to the ground??????????? Seems to me it's not complicated task, but i am confused!
use a point sop and set the normal to 0 1 0, .. so it points up into y direction.
Seb
I tryied to do the same things, but nothing happened, so that's why I'm so confused))
road.hipnc (56.3 KB)
have alook, into the file, ive just used the 3rd input for the reference points and a transform node to the original points which are sweeped
road_101.hipnc (56.3 KB)
Yes! Everything is working! Thx a lot Seb!!!
