I've seem to have hit a roadblock in my attempts to make some realistic looking rock objects.. I am using a displacement map for the displacement of the surface and then am using a large high resolution photo of a rock surface. The issue is that I am using a UV project SOP on the object and I have a different size for the displacement map vs the texture map, for example I want to tile the displacement map many times over while I am not tiling the texture map at all.. using just one UV seems to leave no way to specify different values for each.. if anyone has an idea on how to do this I would greatly appreciate your input.
edit: maybe this is easier than I thought? I've been reading through stuff online and seen some hints that I can just create multiple UVs for an object so I'll try that
Different UV parameters for displacement map and texture map
7623 7 0-
- rdane1010
- 120 posts
- Siavash Tehrani
- 737 posts
Yep, you can create multiple sets of UVs. Set down a layer SOP and change the layer number. Create a new set of UVs on that layer. So for layer 2, the name of the attribute would be uv2, for layer 3, it would be uv3 and so on and so forth…
Then in your shader you can specify which set of UVs you want for which parts.
- rdane1010
- 120 posts
- rdane1010
- 120 posts
- Siavash Tehrani
- 737 posts
Ah sorry, I assumed you were making shaders in VOPs. If you're using the Basic Displacement material that ships with Houdini you can dive inside its vopnet and change which layer it's using. Go into the shader and dive inside the uvcoords1 node. In there you will find a node named “shadingAttriUV”. It's a Shading Layer Parameter VOP, which you'll notice it has a layer option.
Hope that helps.
Hope that helps.
- rdane1010
- 120 posts
- rdane1010
- 120 posts
- circusmonkey
- 2624 posts
See the attached file.
In Vop network for the shader look for the texture vop in both the displacement vop network and the surface shader vop network. Note the nodes I have added which are blue in colour.
In the grids SOP network. MMB on the different nodes and you will see , uv , uv2 attributes added.
r
r
Gone fishing
