How to specify the directory of a file in a Python type operator in Houdini which is running on Mac OS system? Is it the same as in Windows system?
e.g. I want to write Python script in a Python type operator to export certain attribute of all the primitives to a text file, then what is the Python code to write this list of attribute values to a specific text file within a specific folder on the harddisk of a Mac computer?
how to specify file directory in Python in Houdini in Mac OS
5258 2 0-
- oat
- 479 posts
- graham
- 1926 posts
It's no different on any operating system. You just open a file path to write to, write the data and close it.
You can also just create a file parameter on your SOP to point to where you want the file to be and then use that to get the path.
filepath = hou.pwd().evalParm(“file”)
f = open(filepath, “w”)
f.write(your data)
f.close()
f.write(your data)
f.close()
- oat
- 479 posts
Dear graham, Thank you very much for your kind help!
will try later according to your suggestion.
graham
f.write(your data)
f.close()
