I'm trying to export a RIB with motion blur. However I can't get the MotionBegin block to be set to 0 1, even though I force it in my export.
I've attached a sample scene for you guys to try with.
On my system it produces a RIB with MotionBegin .
Is there any parameter somewhere which I should change perhaps?
Thanks in advance.
RIB export motion blur problem
3540 3 1-
- xtimmyx
- 166 posts
- cosku
- 3 posts
Hey,
I opened your scene in 10.0.339-linux, and the exported .rib does have the proper Motion block.
# Geometry object /obj/box_object1
MotionBegin # {
Transform
Transform
MotionEnd # }
When I turn off “Force shutter/motion block time”, the motion block turns to:
MotionBegin
I don't know what's causing the problem on your end though.
-c
MotionBegin # {
Transform
Transform
MotionEnd # }
MotionBegin
-c
- xtimmyx
- 166 posts
- xtimmyx
- 166 posts
