how to "import" or "connect with" anothe
   6972   4   1
suppose you have one houdini file A containing the geometry transformation operation nodes.
how to import another houdini file B which contains the geometry to be manipulated only into file A rather than opening two houdini sessions and copying the geometry nodes from file B and paste it in file A?
thanks!
Try File -> Merge.
thank you very much, graham!
oat
Or just write out the geometry from file A into a .bgeo file and read it into file B with a file SOP. If you're talking more about a process, then an HDA might be appropriate, as that essentially encapsulates the process and makes it portable.
Antoine Durr
Floq FX
antoine@floqfx.com
_________________
Thank you very much Antoine!
