Hi
How can I determine minimum or maximum value of any sop attribute?
For example I have connectivity sop that creates some attributes on the primitives. I would like to figure out the min-maximum values of particular attribute.
I also would like to find out how many unique attributes there are in given Sop
thanks
Max, min value and number of unique values of an attribute?
7999 3 1-
- kursad
- 88 posts
- graham
- 1926 posts
You can use the Attribute Promote SOP to get the min/max values of any attribute.
Getting the number of individual attribute values is trickier. Personally I'd do it using Python with the result of hou.Geometry.pointFloatAttribValues(). This gives you a list of all the attribute values, which you could then convert to a Python set and get the count of individual elements.
- kursad
- 88 posts
- kursad
- 88 posts
