Creating a node to switch between inputs
   3821   3   1
I would like to create a new node which would have multiple inputs and that would output only one of them according to the value of its parameter (a slider or a combo box).
This is to easily switch between a primitove object and its proxy or between several primitive objects (sphere, cube…) in a geometry network.
Should I use a Vex node?
It there an other way to do so than creating a new node?
Thank you very much,
Werwack
Video Game Graphics TD
Is there a reason you can't use the Switch SOP?
werwack
Werwack
Umm … switch SOP?
Rob
Digital Supervisor | Stargate Studios Toronto
Thanks to both of you.
Indeed Switch does exactly what I was looking for.
I used wrong keywords when I looked into the doc, apparently, because this this one sounds obvious.
I'll try to dig a bit more, next time.
Best,
werwack
