GLSL parameters instancing
   4166   4   0
Hi all,
How can i instance GLSL material parameters with “copy SOP” ?
For example:
I can instance “Cd” or “Alpha” or “scale” or “pscale” attribute. But i can't link random textures in one material.
I can do this but i see changes only when render with Mantra. But i don't see this in viewport.
I mean GLSL shader parameter - when i use “Override use local variables” then i choose “base texture map” or “ogl_tex1” - but nothing happened in viewport. Only when i render with mantra - i can see different textures on copies. But not in viewport.
This is not implemented in Houdini ? Or i don't know some hints? I have trying many shaders and i have to try many of ready Houdini shaders - i see same effect…
Thanks for answers..
Thanks for hurricane response ! ))
It seems nobody understood my issue. Ok i will try again:
1. Look to attached scene.
2. There a simple setup, but i can't get it worked.
I need. See material overrides in the viewport. I can send Point Color attribute to GLSL shader and i see it works. But i can't properly send “map” or “texture” point attribute to GLSL shader.
How i can do that ?
GLSL_problem.hipnc (288.2 KB)
Material overrides are not visualized in the viewport.
twod
Pain..
Up to now version 13, aren't material overrides visualized in the viewport ?
