Trace node?
   5032   2   1
Hi all, having a bit of trouble using the Trace node. Can anyone give me a few pointers or point me to a good tutorial? Cheers.
JT
Hi JT,
Can you please give more details about your trouble with the Trace SOP? It helps to make the image more contrasting or black & white if you can. Also, you might want to adjust the Threshold parameter to get a better trace.
Cheers!
steven
Hi Steven, thanks for the quick reply. You were right, I was having trouble due to the image contrast. Problem solved! Thanks again.
JT
