obj normal's problem ( on specularity and reflections only )
   5672   3   1
Hi everyone ,
i'm having a ‘strange’ appearance ( rendering ) of my model . first pic …
it might look ‘interesting’ but it is not what i intended … . i'm referring to the tri-quatro-penta angular strange patterns . the surface should appear a smooth shaded one with some specularity and reflections on top of it .
my model is an exported one after i sculpted it in Sculptris , so it is an Obj with lots of ( and exclusively ) triangles . the other screenshots are taken from a ‘bite’ of the model extracted simply with a delete sop .
primitive's normals … appear ok . also rendering with and Reflect Lights and Reflect Objects Off … appear ok . the undesired effect appears only when i activate Reflect Lights and / Reflect Objects in the materials panel . ( i'm using a StainlessSteel as material and the default Mantra renderer options )
> any suggestion how can i resolve this ?
.thanks
except the things that cannot be seen , nothing is like it seems .
I guess that you use the anisotropic reflection and you do not set the “tangent style” properly.
P.S.
Also you can look the “Houdini journals” for latest builds.
Alexey Mazurenko
oh , thanks archie ! that was it …
every other option on Tangent Style menu ( beside the Geometric Tangent ) gave me slightly different results , but shading appeared correct .
anyway , thanks again .
.cheers
Hi Zarti,
I think that the “Geometric Tangent” will work properly in latest builds. There has fixed a few problems for phonglobe() that typically being used for reflection by default.
Alexey Mazurenko
