Houdini 11 Apprentice install woes
   4230   3   2
I'm trying to install Houdini 11 Apprentice on OS-X 10.5.8
The install log complains of inconsistent tabs and spaces in a python script somewhere, The line that's causing the problem reads, “ raise RuntimeError()” So I think the real problem is something else. When I try to open the file with the errant line in it to see what is trying to raise an exception, the file isn't there anymore.
Anyone else hit this problem? Any suggestions?
from the install log:
Feb 13 16:58:42 Spoonheimer runner: Extracting BOM from “/Volumes/Houdini/Houdini.pkg” to “/Library/Receipts/boms/com.sidefx.houdiniuninstaller-11.0.581.pkg.bom”
Feb 13 16:58:42 Spoonheimer Installer: Processing foldericon:
Feb 13 16:58:42 Spoonheimer Installer: Determining files to install
Feb 13 16:58:42 Spoonheimer Installer: It took 0.00 seconds to create the install plan for foldericon.
Feb 13 16:58:42 Spoonheimer Installer: Configuring deferred files
Feb 13 16:58:42 Spoonheimer Installer: Determining obsolete files
Feb 13 16:58:42 Spoonheimer Installer: Assembling temporary receipt
Feb 13 16:58:42 Spoonheimer Installer: Performing pre-extraction actions
Feb 13 16:58:42 Spoonheimer Installer: Removing obsoleted files
Feb 13 16:58:42 Spoonheimer Installer: Creating destination path
Feb 13 16:58:42 Spoonheimer Installer: Validating package payload
Feb 13 16:58:42 Spoonheimer Installer: Starting file extraction
Feb 13 16:58:42 Spoonheimer payloadExtractor: Initializing new flat-package receipt.
Feb 13 16:58:42 Spoonheimer payloadExtractor: Extracting…
Feb 13 16:58:42 Spoonheimer payloadExtractor: 2 of 2 files written in 0.01 seconds.
Feb 13 16:58:42 Spoonheimer payloadExtractor: 292 kilobytes installed at 41.7 MB/s.
Feb 13 16:58:42 Spoonheimer Installer: run postupgrade script for foldericon
Feb 13 16:58:42 Spoonheimer /private/tmp/scripts.vuKh/./postinstall: File “/private/tmp/scripts.vuKh/./postinstall”, line 16
Feb 13 16:58:42 Spoonheimer /private/tmp/scripts.vuKh/./postinstall: raise RuntimeError()
Feb 13 16:58:42 Spoonheimer /private/tmp/scripts.vuKh/./postinstall: ^
Feb 13 16:58:42 Spoonheimer /private/tmp/scripts.vuKh/./postinstall: TabError: inconsistent use of tabs and spaces in indentation
Feb 13 16:58:42 Spoonheimer Installer: Install failed: The following install step failed: run postupgrade script for foldericon. Contact the software manufacturer for assistance.
Feb 13 16:58:43 Spoonheimer Installer: IFDInstallController 885D40 state = 7
Feb 13 16:58:43 Spoonheimer Installer: Displaying ‘Install Failed’ UI.
Feb 13 16:58:43 Spoonheimer Installer: ‘Install Failed’ UI displayed message:'The following install step failed: run postupgrade script for foldericon. Contact the software manufacturer for assistance.'.
Feb 13 16:58:49 Spoonheimer installdb: done. (0.034u + 0.048s)
-derick
I upgraded to OS 10.6.3 and the install went without a hitch.
-derick
Upgrade to Snow Leopard is a good thing. Improved OpenGL support too.
Snow Leopard upgrade fixed the problem for me as well.
www.3drender.co.uk - Pro-Viz(TM) 3D Textures
