random pick points
   16550   3   0
hi every body:
I have a simple problem in recent work.
Is it possible to randomly select 10 points on a mesh at each frame in Houdini? I think it is may be simple, but I can not work it out, hope someone helps. ops:
please.
use Sort SOP with random mode and seed $F
then just select first 10 points by Group SOP (pattern 0-9, point mode)
nice and simple, thank you very MUCH!
Alternatively, you can use a Group by Range SOP and play around with a range filter. Possibly also to change it on every frame ($F) and something else.
Edited by AnimGraphLab - Feb. 14, 2023 14:40:00
Generalist.
Socials: https://linktr.ee/AnimGraphLab [linktr.ee]
