how to open "Houdini Console" in Mac version of Ho
   18795   5   4
may I ask how to open the “houdini console” window in the Mac OS version of Houdini?
thanks!
There is no specific console window on OS X or linux. If you want console output you'll need to start Houdini from a terminal. To do this on OS X you can use the Houdini Shell.terminal link in the application folder and type in ‘houdini’. As with linux, you can also navigate to the installation directory and source houdini_setup and then run ‘houdini’.
You could also simply start the “console” app that's in the Utilities folder. There you can filter your output for “houdini” or “mantra”.
found this old post - because was looking for the same - here is my updated nodelist, inclusive mops, in JSON:
  "polysplit": "polysplit",
  "wire": "wire",
  "heightfield_scatter::2.0": "heightfield_scatter::2.0",
  "agentunpack": "agentunpack",
  "heightfield_remap": "heightfield_remap",
  "gamedev::sop_delight": "gamedev::sop_delight",
  "heightfield_project": "heightfield_project",
  "heightfield_erode::2.0": "heightfield_erode::2.0",
  "oceansource": "oceansource",
  "hole": "hole",
  "rbdpaint": "rbdpaint",
  "volumeanalysis": "volumeanalysis",
  "Sop/rbdmaterialfracture::rbdconcretefracture": "Sop/rbdmaterialfracture::rbdconcretefracture",
  "vex": "vex",
  "heightfield_copylayer": "heightfield_copylayer",
  "ripple::2.0": "ripple::2.0",
  "gamedev::rop_volume_texture": "gamedev::rop_volume_texture",
  "volumeblur": "volumeblur",
  "slidemodifierpaint": "slidemodifierpaint",
  "resample": "resample",
  "matchtopology": "matchtopology",
  "agentedit": "agentedit",
  "packgroom": "packgroom",
  "guidegroup": "guidegroup",
  "block_begin": "block_begin",
  "crowdsource": "crowdsource",
  "gamedev::sop_physics_painter": "gamedev::sop_physics_painter",
  "blast": "blast",
  "fractal": "fractal",
  "heightfield_patch": "heightfield_patch",
  "solver": "solver",
  "vertex": "vertex",
  "magnet": "magnet",
  "vdbreshapesdf": "vdbreshapesdf",
  "waveform": "waveform",
  "volumefeather": "volumefeather",
  "repack": "repack",
  "uvunwrap": "uvunwrap",
  "cap": "cap",
  "force": "force",
  "timeblend": "timeblend",
  "agentprep": "agentprep",
  "gamedev::sop_make_loop": "gamedev::sop_make_loop",
  "MOPS::Relax_Copies::1.0": "MOPS::Relax_Copies::1.0",
  "xformaxis": "xformaxis",
  "polyloft": "polyloft",
  "volumevop": "volumevop",
  "volumefft": "volumefft",
  "cloudnoise": "cloudnoise",
  "deformmeta": "deformmeta",
  "MOPS::Parallel_Transport::1.0": "MOPS::Parallel_Transport::1.0",
  "edgecusp": "edgecusp",
  "unpaste": "unpaste",
  "fillet": "fillet",
  "vdbfracture": "vdbfracture",
  "uvlayout": "uvlayout",
  "vdbtopologytosdf": "vdbtopologytosdf",
  "MOPS::Flocking::1.0": "MOPS::Flocking::1.0",
  "gamedev::sop_color_blend": "gamedev::sop_color_blend",
  "bakeode": "bakeode",
  "gamedev::sop_mesh_tiler": "gamedev::sop_mesh_tiler",
  "sopnet": "sopnet",
  "groomblend": "groomblend",
  "primitivesplit": "primitivesplit",
  "captureproximity": "captureproximity",
  "MOPS::Remap_Falloff::1.0": "MOPS::Remap_Falloff::1.0",
  "join": "join",
  "vdbpointsgroup": "vdbpointsgroup",
  "attribrandomize": "attribrandomize",
  "tristrip": "tristrip",
  "voronoifracturepoints": "voronoifracturepoints",
  "vdbclip": "vdbclip",
  "vopnet": "vopnet",
  "gltf": "gltf",
  "box": "box",
  "convert": "convert",
  "oceanevaluate::2.0": "oceanevaluate::2.0",
  "testgeometry_shaderball": "testgeometry_shaderball",
  "remesh": "remesh",
  "grouppromote": "grouppromote",
  "uvlayout::2.0": "uvlayout::2.0",
  "boolean::2.0": "boolean::2.0",
  "scatter": "scatter",
  "uvflatten::2.0": "uvflatten::2.0",
  "sblend::2.0": "sblend::2.0",
  "visibility": "visibility",
  "attribnoise": "attribnoise",
  "crowdsource::2.0": "crowdsource::2.0",
  "agentvellumunpack": "agentvellumunpack",
  "pack": "pack",
  "flipsource": "flipsource",
  "filemerge": "filemerge",
  "vellumsolver": "vellumsolver",
  "divide": "divide",
  "guideprocess": "guideprocess",
  "layer": "layer",
  "agentprep::3.0": "agentprep::3.0",
  "unix": "unix",
  "MOPS::MOPs_Spread_Falloff::1.1": "MOPS::MOPs_Spread_Falloff::1.1",
  "alembicprimitive": "alembicprimitive",
  "attribcopy": "attribcopy",
  "heightfield_quickshade": "heightfield_quickshade",
  "cloud": "cloud",
  "heightfield_terrace": "heightfield_terrace",
  "graphcolor": "graphcolor",
  "gamedev::sop_soften_normals": "gamedev::sop_soften_normals",
  "volumebreak": "volumebreak",
  "gamedev::rbd_solver": "gamedev::rbd_solver",
  "dopio": "dopio",
  "objnet": "objnet",
  "duplicate": "duplicate",
  "bonecapturebiharmonic": "bonecapturebiharmonic",
  "finalizewaves": "finalizewaves",
  "gamedev::sop_group_by_color": "gamedev::sop_group_by_color",
  "volumerasterizehair": "volumerasterizehair",
  "connectadjacentpieces": "connectadjacentpieces",
  "heightfield_isolatelayer": "heightfield_isolatelayer",
  "relax": "relax",
  "guidetangentspace": "guidetangentspace",
  "starburst": "starburst",
  "falloff": "falloff",
  "uvflatten": "uvflatten",
  "planarpleat": "planarpleat",
  "testgeometry_crag": "testgeometry_crag",
  "vectordeform": "vectordeform",
  "gamedev::sop_simple_baker": "gamedev::sop_simple_baker",
  "agent": "agent",
  "gamedev::sop_box_clip": "gamedev::sop_box_clip",
  "posescope": "posescope",
  "findshortestpath": "findshortestpath",
  "unpack": "unpack",
  "gamedev::sop_group_attribute_borders": "gamedev::sop_group_attribute_borders",
  "smooth::2.0": "smooth::2.0",
  "hairclump": "hairclump",
  "gamedev::sop_static_fracture_export": "gamedev::sop_static_fracture_export",
  "vdbfrompolygons": "vdbfrompolygons",
  "gamedev::sop_visualize_uvs": "gamedev::sop_visualize_uvs",
  "extractcentroid": "extractcentroid",
  "stroke": "stroke",
  "vellumconstraints": "vellumconstraints",
  "Object/musclerig::musclerigstrokebuilder": "Object/musclerig::musclerigstrokebuilder",
  "gamedev::sop_instant_meshes": "gamedev::sop_instant_meshes",
  "capturemeta": "capturemeta",
  "ropnet": "ropnet",
  "dissolve": "dissolve",
  "attribpromote": "attribpromote",
  "control": "control",
  "metagroups": "metagroups",
  "groupcopy": "groupcopy",
  "attribute": "attribute",
  "bonelink": "bonelink",
  "guidegroom": "guidegroom",
  "deformmuscle": "deformmuscle",
  "heightfield_maskbyfeature": "heightfield_maskbyfeature",
  "sphere": "sphere",
  "gamedev::sop_sweep_geometry": "gamedev::sop_sweep_geometry",
  "vdbtospheres": "vdbtospheres",
  "bend": "bend",
  "vdbresample": "vdbresample",
  "volumesurface": "volumesurface",
  "particlefluidtank": "particlefluidtank",
  "posespacedeformcombine": "posespacedeformcombine",
  "volumevisualization": "volumevisualization",
  "gamedev::sop_rbd_fracture": "gamedev::sop_rbd_fracture",
  "vellumpostprocess": "vellumpostprocess",
  "dopimportrecords": "dopimportrecords",
  "foreach": "foreach",
  "attribfind": "attribfind",
  "uvautoseam": "uvautoseam",
  "attribwrangle": "attribwrangle",
  "attribfrommap": "attribfrommap",
  "hairgen": "hairgen",
  "profile": "profile",
  "hairgencore": "hairgencore",
  "vdbvectorsplit": "vdbvectorsplit",
  "pointmap": "pointmap",
  "vellumio": "vellumio",
  "connectivity": "connectivity",
  "wiredeform": "wiredeform",
  "volumevelocityfromcurves": "volumevelocityfromcurves",
  "heightfield_erode": "heightfield_erode",
  "edgeflip": "edgeflip",
  "MOPS::Sweep_Spline::1.0": "MOPS::Sweep_Spline::1.0",
  "stash": "stash",
  "gamedev::niagara_impacts": "gamedev::niagara_impacts",
  "drawcurve": "drawcurve",
  "MOPS::Subdivider::1.0": "MOPS::Subdivider::1.0",
  "superquad": "superquad",
  "agentcollisionlayer": "agentcollisionlayer",
  "attribvop": "attribvop",
  "deform": "deform",
  "MOPS::Spline_Falloff::1.0": "MOPS::Spline_Falloff::1.0",
  "timeshift": "timeshift",
  "grainsource": "grainsource",
  "wavevelocity": "wavevelocity",
  "revolve": "revolve",
  "heightfield_drawmask": "heightfield_drawmask",
  "MOPS::Randomize::1.1": "MOPS::Randomize::1.1",
  "MOPS::Randomize::1.0": "MOPS::Randomize::1.0",
  "platonic": "platonic",
  "volumesplice": "volumesplice",
  "groomswitch": "groomswitch",
  "attribtransferbyuv": "attribtransferbyuv",
  "attribreorient": "attribreorient",
  "cloudlight": "cloudlight",
  "group": "group",
  "edgefracture": "edgefracture",
  "fit": "fit",
  "heightfield_file": "heightfield_file",
  "solidembed": "solidembed",
  "unpackpoints": "unpackpoints",
  "gamedev::sop_measure_curvarture": "gamedev::sop_measure_curvarture",
  "carve": "carve",
  "gamedev::sop_merge_small_islands": "gamedev::sop_merge_small_islands",
  "heightfield_layer": "heightfield_layer",
  "block_end": "block_end",
  "MOPS::Set_Sequence_Time::1.0": "MOPS::Set_Sequence_Time::1.0",
  "material": "material",
  "shatter": "shatter",
  "trail": "trail",
  "break": "break",
  "volumepatch": "volumepatch",
  "filament_advect_pos": "filament_advect_pos",
  "polypatch": "polypatch",
  "heightfield_resample": "heightfield_resample",
  "uvlayout::3.0": "uvlayout::3.0",
  "gamedev::sop_calculate_occlusion": "gamedev::sop_calculate_occlusion",
  "wirecapture": "wirecapture",
  "adaptiveprune": "adaptiveprune",
  "name": "name",
  "polybridge": "polybridge",
  "edit": "edit",
  "gamedev::sop_thicken": "gamedev::sop_thicken",
  "merge": "merge",
  "heightfield_layerclear": "heightfield_layerclear",
  "vdbsmooth": "vdbsmooth",
  "each": "each",
  "extrudevolume": "extrudevolume",
  "groupdelete": "groupdelete",
  "vdbcombine": "vdbcombine",
  "rbdinteriordetail": "rbdinteriordetail",
  "gamedev::sop_disc_generator": "gamedev::sop_disc_generator",
  "heightfield_blur": "heightfield_blur",
  "whitewatersource::2.0": "whitewatersource::2.0",
  "mdd": "mdd",
  "rop_gltf": "rop_gltf",
  "gamedev::sop_extract_filename": "gamedev::sop_extract_filename",
  "paintsdfvolume": "paintsdfvolume",
  "measure": "measure",
  "ripple": "ripple",
  "vdbfromparticles": "vdbfromparticles",
  "convertvdbpoints": "convertvdbpoints",
  "subnet": "subnet",
  "grouprange": "grouprange",
  "polybevel": "polybevel",
  "network": "network",
  "MOPS::indexFromAttribute::1.0": "MOPS::indexFromAttribute::1.0",
  "edgetransport": "edgetransport",
  "collisionsource": "collisionsource",
  "gamedev::sop_mapbox": "gamedev::sop_mapbox",
  "planarpatchfromcurves": "planarpatchfromcurves",
  "tetrahedralize": "tetrahedralize",
  "agentclip": "agentclip",
  "vdbvisualizetree": "vdbvisualizetree",
  "uvproject": "uvproject",
  "vdbmorphsdf": "vdbmorphsdf",
  "testgeometry_squab": "testgeometry_squab",
  "cookie": "cookie",
  "polyreduce::2.0": "polyreduce::2.0",
  "convexdecomposition": "convexdecomposition",
  "capturecorrect": "capturecorrect",
  "MOPS::Explode::1.0": "MOPS::Explode::1.0",
  "volumerasterizeattributes": "volumerasterizeattributes",
  "MOPS::delay::1.0": "MOPS::delay::1.0",
  "alembicgroup": "alembicgroup",
  "gamedev::sop_unreal_pivotpainter": "gamedev::sop_unreal_pivotpainter",
  "heightfield_xform": "heightfield_xform",
  "round": "round",
  "guideadvect": "guideadvect",
  "iso": "iso",
  "grouptransfer": "grouptransfer",
  "gamedev::sop_flowmap_obstacle": "gamedev::sop_flowmap_obstacle",
  "fluidsource": "fluidsource",
  "vopsoptype": "vopsoptype",
  "clothcapture": "clothcapture",
  "extrude": "extrude",
  "heightfield_visualize": "heightfield_visualize",
  "polyknit": "polyknit",
  "sssscatter": "sssscatter",
  "enumerate": "enumerate",
  "gamedev::sop_terrain_segment_rop": "gamedev::sop_terrain_segment_rop",
  "gamedev::sop_quickmaterial": "gamedev::sop_quickmaterial",
  "dopimport": "dopimport",
  "heightfield": "heightfield",
  "extracttransform": "extracttransform",
  "volumerasterize": "volumerasterize",
  "pointjitter": "pointjitter",
  "polyexpand2d": "polyexpand2d",
  "blendshapes::2.0": "blendshapes::2.0",
  "script": "script",
  "guideskinattriblookup": "guideskinattriblookup",
  "rails": "rails",
  "gamedev::simple_rbd": "gamedev::simple_rbd",
  "paint": "paint",
  "vdblod": "vdblod",
  "polyextrude::2.0": "polyextrude::2.0",
  "inflate": "inflate",
  "MOPS::Mesh_Flow::1.0": "MOPS::Mesh_Flow::1.0",
  "MOPS::Mesh_Flow::1.1": "MOPS::Mesh_Flow::1.1",
  "attribblur": "attribblur",
  "attribfade": "attribfade",
  "attribcreate::2.0": "attribcreate::2.0",
  "agentdefinitioncache": "agentdefinitioncache",
  "groomfetch": "groomfetch",
  "copy": "copy",
  "MOPS::Object_Falloff::1.0": "MOPS::Object_Falloff::1.0",
  "xform": "xform",
  "fluidcompress": "fluidcompress",
  "gamedev::rbd_director": "gamedev::rbd_director",
  "vdbadvectpoints": "vdbadvectpoints",
  "vertexsplit": "vertexsplit",
  "heightfield_maskbyshadow": "heightfield_maskbyshadow",
  "project": "project",
  "agentconfigurejoints": "agentconfigurejoints",
  "convertvolume": "convertvolume",
  "bridge": "bridge",
  "clip": "clip",
  "agentproxy": "agentproxy",
  "cop2net": "cop2net",
  "lsystem": "lsystem",
  "topobuild": "topobuild",
  "constraintnetwork": "constraintnetwork",
  "gamedev::sop_flowmap_visualize": "gamedev::sop_flowmap_visualize",
  "scatter::2.0": "scatter::2.0",
  "pointdeform": "pointdeform",
  "gamedev::sop_terrain_texture_rop": "gamedev::sop_terrain_texture_rop",
  "ray": "ray",
  "mountain": "mountain",
  "posespacedeform": "posespacedeform",
  "tetrahedralize::2.0": "tetrahedralize::2.0",
  "groupexpression": "groupexpression",
  "polyfill": "polyfill",
  "pointvelocity": "pointvelocity",
  "pointreplicate": "pointreplicate",
  "switch": "switch",
  "paintcolorvolume": "paintcolorvolume",
  "gamedev::sop_polydeform": "gamedev::sop_polydeform",
  "MOPS::Shape_Falloff::1.1": "MOPS::Shape_Falloff::1.1",
  "pointcloudiso": "pointcloudiso",
  "deltamush": "deltamush",
  "channel": "channel",
  "polypath": "polypath",
  "attribinterpolate": "attribinterpolate",
  "MOPS::Transform_Falloff::1.0": "MOPS::Transform_Falloff::1.0",
  "guidepartition": "guidepartition",
  "trace": "trace",
  "normal": "normal",
  "captureattribpack": "captureattribpack",
  "toonshaderattribs": "toonshaderattribs",
  "heightfield_slump": "heightfield_slump",
  "bakevex": "bakevex",
  "solidify::2.0": "solidify::2.0",
  "MOPS::Extract_Attributes::1.0": "MOPS::Extract_Attributes::1.0",
  "gamedev::sop_skinning_converter": "gamedev::sop_skinning_converter",
  "guidedeform": "guidedeform",
  "filecache": "filecache",
  "hairgrowthfield": "hairgrowthfield",
  "agenttransformgroup": "agenttransformgroup",
  "torus": "torus",
  "partition": "partition",
  "attribmirror": "attribmirror",
  "polycap": "polycap",
  "clean": "clean",
  "heightfield_paint": "heightfield_paint",
  "attribstringedit": "attribstringedit",
  "pointsfromvolume": "pointsfromvolume",
  "shop": "shop",
  "edgedivide": "edgedivide",
  "Sop/rbdmaterialfracture::rbdwoodfracture": "Sop/rbdmaterialfracture::rbdwoodfracture",
  "hairclump::2.0": "hairclump::2.0",
  "vdbactivate": "vdbactivate",
  "uvtransform": "uvtransform",
  "gamedev::sop_remove_inside_faces": "gamedev::sop_remove_inside_faces",
  "guidedraw": "guidedraw",
  "grouppaint": "grouppaint",
  "font": "font",
  "posespaceedit": "posespaceedit",
  "gamedev::sop_multi_file": "gamedev::sop_multi_file",
  "gamedev::sop_group_by_attribute": "gamedev::sop_group_by_attribute",
  "cache": "cache",
  "volumevelocity": "volumevelocity",
  "texture": "texture",
  "attribexpression": "attribexpression",
  "gamedev::sop_flowmap_guide": "gamedev::sop_flowmap_guide",
  "heightfield_layerproperty": "heightfield_layerproperty",
  "circle": "circle",
  "gamedev::niagara_interpolate": "gamedev::niagara_interpolate",
  "matnet": "matnet",
  "gamedev::sop_sketchfab_output": "gamedev::sop_sketchfab_output",
  "bonedeform": "bonedeform",
  "invoke": "invoke",
  "popnet": "popnet",
  "vdbfromparticlefluid": "vdbfromparticlefluid",
  "heightfield_erode_precipitation": "heightfield_erode_precipitation",
  "uvfuse": "uvfuse",
  "pointgenerate": "pointgenerate",
  "polyreduce": "polyreduce",
  "muscledeform": "muscledeform",
  "agentrelationship": "agentrelationship",
  "uvflatten::3.0": "uvflatten::3.0",
  "heightfield_erode_hydro": "heightfield_erode_hydro",
  "vdbrenormalizesdf": "vdbrenormalizesdf",
  "solidconform": "solidconform",
  "heightfield_pattern": "heightfield_pattern",
  "MOPS::Color_Modifier::1.0": "MOPS::Color_Modifier::1.0",
  "gamedev::sop_destruction_cleanup": "gamedev::sop_destruction_cleanup",
  "smooth": "smooth",
  "voronoifracture": "voronoifracture",
  "agentprep::2.0": "agentprep::2.0",
  "intersectionstitch": "intersectionstitch",
  "polystitch": "polystitch",
  "curveclay": "curveclay",
  "polywire": "polywire",
  "MOPS::Instancer::1.1": "MOPS::Instancer::1.1",
  "MOPS::Instancer::1.0": "MOPS::Instancer::1.0",
  "clothdeform": "clothdeform",
  "gamedev::sop_mark_seams": "gamedev::sop_mark_seams",
  "rbdcluster": "rbdcluster",
  "captureattribunpack": "captureattribunpack",
  "rewire": "rewire",
  "heightfield_crop": "heightfield_crop",
  "volumestamp": "volumestamp",
  "wireblend": "wireblend",
  "solidfracture::2.0": "solidfracture::2.0",
  "vdbanalysis": "vdbanalysis",
  "polydoctor": "polydoctor",
  "ends": "ends",
  "agentcliptransitiongraph": "agentcliptransitiongraph",
  "gamedev::sop_cylinder_generator": "gamedev::sop_cylinder_generator",
  "MOPS::Audio_Falloff:1.0": "MOPS::Audio_Falloff:1.0",
  "bakevolume": "bakevolume",
  "refine": "refine",
  "oceanspectrum": "oceanspectrum",
  "heightfield_flowfield": "heightfield_flowfield",
  "oceanevaluate": "oceanevaluate",
  "MOPS::Noise_Falloff::1.0": "MOPS::Noise_Falloff::1.0",
  "gamedev::sop_extract_borders": "gamedev::sop_extract_borders",
  "comb": "comb",
  "collisionsource::2.0": "collisionsource::2.0",
  "loadslices": "loadslices",
  "object_merge": "object_merge",
  "gamedev::sop_color_adjustment": "gamedev::sop_color_adjustment",
  "volumearrivaltime": "volumearrivaltime",
  "rbdpack": "rbdpack",
  "reverse": "reverse",
  "volumefromattrib": "volumefromattrib",
  "chopnet": "chopnet",
  "volumerasterizepoints": "volumerasterizepoints",
  "facet": "facet",
  "guideinit": "guideinit",
  "polybevel::2.0": "polybevel::2.0",
  "gamedev::sop_axis_align": "gamedev::sop_axis_align",
  "Sop/rbdmaterialfracture::rbdglassfracture": "Sop/rbdmaterialfracture::rbdglassfracture",
  "uvpelt::2.0": "uvpelt::2.0",
  "point": "point",
  "color": "color",
  "sky": "sky",
  "gamedev::sop_flowmap_obstacle::2.0": "gamedev::sop_flowmap_obstacle::2.0",
  "gamedev::sop_delete_small_parts": "gamedev::sop_delete_small_parts",
  "blendshapes": "blendshapes",
  "sweep": "sweep",
  "pop": "pop",
  "vopsop": "vopsop",
  "xformbyattrib": "xformbyattrib",
  "agentlookat::2.0": "agentlookat::2.0",
  "gamedev::sop_edgegroup_to_curve": "gamedev::sop_edgegroup_to_curve",
  "gamedev::sop_turntable": "gamedev::sop_turntable",
  "gamedev::sphere_generator": "gamedev::sphere_generator",
  "basis": "basis",
  "volumecompress": "volumecompress",
  "MOPS::Plain_Falloff::1.0": "MOPS::Plain_Falloff::1.0",
  "voronoisplit": "voronoisplit",
  "Object/riggedmuscle::musclestrokebuilder": "Object/riggedmuscle::musclestrokebuilder",
  "polysplit::2.0": "polysplit::2.0",
  "volumebound": "volumebound",
  "agentconstraintnetwork": "agentconstraintnetwork",
  "heightfield_maskbyocclusion": "heightfield_maskbyocclusion",
  "groupcreate": "groupcreate",
  "whitewatersource": "whitewatersource",
  "surfsect": "surfsect",
  "intersectionanalysis": "intersectionanalysis",
  "volumeresample": "volumeresample",
  "sprite": "sprite",
  "vdbadvectsdf": "vdbadvectsdf",
  "volumereduce": "volumereduce",
  "uvedit": "uvedit",
  "windingnumber": "windingnumber",
  "gamedev::sop_uv_unitize": "gamedev::sop_uv_unitize",
  "vdbocclusionmask": "vdbocclusionmask",
  "cregion": "cregion",
  "fur": "fur",
  "sculpt": "sculpt",
  "align": "align",
  "copyxform": "copyxform",
  "crowdsource::3.0": "crowdsource::3.0",
  "error": "error",
  "shopnet": "shopnet",
  "MOPS::Falloff_From_Attribute::1.0": "MOPS::Falloff_From_Attribute::1.0",
  "gamedev::sop_flowmap": "gamedev::sop_flowmap",
  "convertmeta": "convertmeta",
  "Sop/rbdmaterialfracture::rbdrecursivefracture": "Sop/rbdmaterialfracture::rbdrecursivefracture",
  "curvesect": "curvesect",
  "MOPS::MOPs_Spread_Falloff::1.0": "MOPS::MOPs_Spread_Falloff::1.0",
  "attribtransfer": "attribtransfer",
  "MOPS::Texture_Falloff::1.0": "MOPS::Texture_Falloff::1.0",
  "gamedev::inside_face_uvs": "gamedev::inside_face_uvs",
  "booleanfracture": "booleanfracture",
  "cluster": "cluster",
  "retime": "retime",
  "reguide": "reguide",
  "tableimport": "tableimport",
  "capture": "capture",
  "null": "null",
  "tetpartition": "tetpartition",
  "MOPS::Aim::1.0": "MOPS::Aim::1.0",
  "python": "python",
  "vellumrestblend": "vellumrestblend",
  "split": "split",
  "drawhair": "drawhair",
  "heightfield_scatter": "heightfield_scatter",
  "triangulate2d::3.0": "triangulate2d::3.0",
  "packededit": "packededit",
  "captureoverride": "captureoverride",
  "dopimportfield": "dopimportfield",
  "groupcombine": "groupcombine",
  "xformpieces": "xformpieces",
  "vellumconstraints_grain": "vellumconstraints_grain",
  "fuse": "fuse",
  "agentlayer": "agentlayer",
  "oceanfoam": "oceanfoam",
  "clusterpoints": "clusterpoints",
  "volumevelocityfromsurface": "volumevelocityfromsurface",
  "voronoifracture::2.0": "voronoifracture::2.0",
  "rop_geometry": "rop_geometry",
  "particlefluidsurface": "particlefluidsurface",
  "pyrosource": "pyrosource",
  "rbdmaterialfracture": "rbdmaterialfracture",
  "compile_begin": "compile_begin",
  "debrissource": "debrissource",
  "agentterrainadaptation": "agentterrainadaptation",
  "packeddiskedit": "packeddiskedit",
  "MOPS::MOPs_Move_Along_Mesh::1.0": "MOPS::MOPs_Move_Along_Mesh::1.0",
  "muscle": "muscle",
  "bonecapturelines": "bonecapturelines",
  "agentclipproperties": "agentclipproperties",
  "skin": "skin",
  "gamedev::sop_sine_wave": "gamedev::sop_sine_wave",
  "rest": "rest",
  "MOPS::Curl_Modifier::1.0": "MOPS::Curl_Modifier::1.0",
  "explodedview": "explodedview",
  "heightfield_erode_thermal": "heightfield_erode_thermal",
  "volumemerge": "volumemerge",
  "guidecollidevdb": "guidecollidevdb",
  "instance": "instance",
  "opencl": "opencl",
  "attribcreate": "attribcreate",
  "rop_fbx": "rop_fbx",
  "guidemaskcore": "guidemaskcore",
  "add": "add",
  "polycut": "polycut",
  "verify_bsdf": "verify_bsdf",
  "isooffset": "isooffset",
  "attribfromvolume": "attribfromvolume",
  "oceanwaves": "oceanwaves",
  "testsim_ragdoll": "testsim_ragdoll",
  "particlefluidsurface::2.0": "particlefluidsurface::2.0",
  "edgecollapse": "edgecollapse",
  "polyspline": "polyspline",
  "deformationwrangle": "deformationwrangle",
  "gamedev::sop_gameres": "gamedev::sop_gameres",
  "MOPS::Spring_Modifier::1.0": "MOPS::Spring_Modifier::1.0",
  "volumeopticalflow": "volumeopticalflow",
  "grid": "grid",
  "MOPS::Neighbors::1.0": "MOPS::Neighbors::1.0",
  "gamedev::rop_vector_field": "gamedev::rop_vector_field",
  "gamedev::sop_group_edge_loop": "gamedev::sop_group_edge_loop",
  "polysoup": "polysoup",
  "convertvdb": "convertvdb",
  "particle": "particle",
  "bulge": "bulge",
  "fevisualization": "fevisualization",
  "gamedev::sop_detail_mesh": "gamedev::sop_detail_mesh",
  "MOPS::MOPS_Convert::1.0": "MOPS::MOPS_Convert::1.0",
  "gamedev::niagara_rop": "gamedev::niagara_rop",
  "vdb": "vdb",
  "clay": "clay",
  "output": "output",
  "lidarimport": "lidarimport",
  "MOPS::Shape_Falloff::1.0": "MOPS::Shape_Falloff::1.0",
  "copytopoints": "copytopoints",
  "unpackgroom": "unpackgroom",
  "testsim_crowdtransition": "testsim_crowdtransition",
  "compile_end": "compile_end",
  "guidetransfer": "guidetransfer",
  "MOPS::Reorient::1.0": "MOPS::Reorient::1.0",
  "heightfield_noise": "heightfield_noise",
  "vdbsmoothsdf": "vdbsmoothsdf",
  "metaball": "metaball",
  "mirror": "mirror",
  "detangle": "detangle",
  "heightfield_tilesplit": "heightfield_tilesplit",
  "creep": "creep",
  "tribez": "tribez",
  "gamedev::sop_quickmaterial::2.0": "gamedev::sop_quickmaterial::2.0",
  "capturemirror": "capturemirror",
  "vdbactivatesdf": "vdbactivatesdf",
  "heightfield_output": "heightfield_output",
  "MOPS::Apply_Attributes::1.0": "MOPS::Apply_Attributes::1.0",
  "gamedev::sop_straighten": "gamedev::sop_straighten",
  "lattice": "lattice",
  "matchsize": "matchsize",
  "vdbdiagnostics": "vdbdiagnostics",
  "testgeometry_pighead": "testgeometry_pighead",
  "knife": "knife",
  "triangulate2d::2.0": "triangulate2d::2.0",
  "convertline": "convertline",
  "visualize": "visualize",
  "guidemask": "guidemask",
  "vellumpack": "vellumpack",
  "gamedev::sop_autouv": "gamedev::sop_autouv",
  "heightfield_distort": "heightfield_distort",
  "uvpelt": "uvpelt",
  "timewarp": "timewarp",
  "shrinkwrap": "shrinkwrap",
  "assemble": "assemble",
  "heightfield_maskbyconcavity": "heightfield_maskbyconcavity",
  "paste": "paste",
  "volumemix": "volumemix",
  "delete_overlapping_polygons": "delete_overlapping_polygons",
  "testgeometry_tommy": "testgeometry_tommy",
  "planarpatch": "planarpatch",
  "testgeometry_rubbertoy": "testgeometry_rubbertoy",
  "solidify": "solidify",
  "convertheightfield": "convertheightfield",
  "gamedev::sop_retime": "gamedev::sop_retime",
  "rishader": "rishader",
  "uvquickshade": "uvquickshade",
  "MOPS::Preview_Falloff::1.1": "MOPS::Preview_Falloff::1.1",
  "MOPS::Preview_Falloff::1.0": "MOPS::Preview_Falloff::1.0",
  "alembic": "alembic",
  "gamedev::sop_flowmap_to_color": "gamedev::sop_flowmap_to_color",
  "primitive": "primitive",
  "polyframe": "polyframe",
  "bound": "bound",
  "softpeak": "softpeak",
  "gamedev::sop_uv_stack": "gamedev::sop_uv_stack",
  "volumerasterizeparticles": "volumerasterizeparticles",
  "musclecapture": "musclecapture",
  "heightfield_maskbyobject": "heightfield_maskbyobject",
  "gamedev::sop_flowmap::2.0": "gamedev::sop_flowmap::2.0",
  "attribcast": "attribcast",
  "agentclip::2.0": "agentclip::2.0",
  "matchaxis": "matchaxis",
  "subdivide": "subdivide",
  "heightfield_distortbylayer": "heightfield_distortbylayer",
  "vellumdrape": "vellumdrape",
  "attribswap": "attribswap",
  "gamedev::sop_osm_import": "gamedev::sop_osm_import",
  "volumeresize": "volumeresize",
  "spring": "spring",
  "uvtransform::2.0": "uvtransform::2.0",
  "volumeconvolve3": "volumeconvolve3",
  "vdbvectormerge": "vdbvectormerge",
  "volumeramp": "volumeramp",
  "Sop/rbdmaterialfracture::rbdrewireconstraints": "Sop/rbdmaterialfracture::rbdrewireconstraints",
  "attribdelete": "attribdelete",
  "volumesdf": "volumesdf",
  "particlefluidmask": "particlefluidmask",
  "vdbprojectnondivergent": "vdbprojectnondivergent",
  "volume": "volume",
  "solidembed::2.0": "solidembed::2.0",
  "heightfield_clip": "heightfield_clip",
  "hairclumpcore": "hairclumpcore",
  "line": "line",
  "haircardgen": "haircardgen",
  "tetrasurface": "tetrasurface",
  "dissolve::2.0": "dissolve::2.0",
  "gamedev::niagara_rbd_split": "gamedev::niagara_rbd_split",
  "gluecluster": "gluecluster",
  "vortexforceattribs": "vortexforceattribs",
  "MOPS::move_along_spline::1.1": "MOPS::move_along_spline::1.1",
  "MOPS::move_along_spline::1.0": "MOPS::move_along_spline::1.0",
  "MOPS::move_along_spline::1.3": "MOPS::move_along_spline::1.3",
  "vdbsegmentbyconnectivity": "vdbsegmentbyconnectivity",
  "triangulate2d": "triangulate2d",
  "rbdunpack": "rbdunpack",
  "gamedev::sop_osm_buildings": "gamedev::sop_osm_buildings",
  "delete": "delete",
  "trim": "trim",
  "sort": "sort",
  "paintfogvolume": "paintfogvolume",
  "gamedev::sop_color_gradient": "gamedev::sop_color_gradient",
  "shapediff": "shapediff",
  "sblend": "sblend",
  "twist": "twist",
  "mountain::2.0": "mountain::2.0",
  "uvbrush": "uvbrush",
  "rbdconstraintproperties": "rbdconstraintproperties",
  "file": "file",
  "gamedev::sop_group_expand": "gamedev::sop_group_expand",
  "agentlookat": "agentlookat",
  "attribcomposite": "attribcomposite",
  "MOPS::Combine_Falloffs::1.0": "MOPS::Combine_Falloffs::1.0",
  "grouprename": "grouprename",
  "strokecache": "strokecache",
  "posespaceeditconfigure": "posespaceeditconfigure",
  "capturelayerpaint": "capturelayerpaint",
  "gamedev::sop_decal_projector": "gamedev::sop_decal_projector",
  "volumerasterizecurve": "volumerasterizecurve",
  "oceansource::2.0": "oceansource::2.0",
  "pointwrangle": "pointwrangle",
  "spraypaint": "spraypaint",
  "solidfracture": "solidfracture",
  "timeblend::2.0": "timeblend::2.0",
  "guideprocesscore": "guideprocesscore",
  "dopnet": "dopnet",
  "shrinkwrap::2.0": "shrinkwrap::2.0",
  "packpoints": "packpoints",
  "peak": "peak",
  "polyextrude": "polyextrude",
  "vellumunpack": "vellumunpack",
  "hairgen::2.0": "hairgen::2.0",
  "stitch": "stitch",
  "MOPS::Transform_Modifier::1.0": "MOPS::Transform_Modifier::1.0",
  "rop_alembic": "rop_alembic",
  "volumetrail": "volumetrail",
  "gamedev::sop_voxelmesh": "gamedev::sop_voxelmesh",
  "curve": "curve",
  "crease": "crease",
  "wiretransfershape": "wiretransfershape",
  "volumeslice": "volumeslice",
  "volumewrangle": "volumewrangle",
  "softxform": "softxform",
  "tissuesolver": "tissuesolver",
  "tube": "tube",
  "tridivide": "tridivide"
Edited by Neonzone - Feb. 14, 2019 04:53:13
For anyone that runs Houdini on Mac and gets similarly frustrated by lack of a console that can always stay on top for printf's and the like, there IS a solution.
Download iTerm2 [iterm2.com], then set up an Alias inside your /Users/username/.zshrc (aka ~/.zshrc) file like so:
alias houdini="/Applications/Houdini/Houdini20.0.506/Frameworks/Houdini.framework/Resources/bin/houdini"
Or whatever version you're running at the time.
Then follow these instructions I found:
One such feature with iTerm2 is the ability to configure a Hotkey Window setting on various iTerm2 profiles. iTerm2 -> Preferences -> Profile -> Keys tab -> Configure Hotkey Window button. Then set a hotkey to launch your Profile and make sure 'Pin hotkey window (stays open on loss of keyboard focus) is checked as well as 'Floating window'.
When you hit the hotkey it will launch iTerm2 and it will stay on top.
You MUST use the hotkey you set in that last step to open the terminal since it will make sure to keep the window on top.
Then type "houdini" and you should be launching whatever version you run (I'm on Indie). It should stay on top and receive all the console data from Houdini.
Trying to get this set up on my MacBook and I keep getting this error in the terminal when launching Houdini 20.0.653:
UNSUPPORTED (log once): POSSIBLE ISSUE: unit 1 GLD_TEXTURE_INDEX_2D is unloadable and bound to sampler type (Float) - using zero texture because texture unloadable
Also followed Len's instructions and installed iTerm. Houdini launches via iTerm and Terminal without issue even with that error, but there seems to be no 'console' connection to the in either case. When I try to run printf in an attribute wrangle I get nothing. However Houdini just crashed and the crash message did show in the terminal. Can't figure out what I'm missing to get this set up. Any help would be appreciated. Running Sonoma 14.5.
