Convert rotation matrix from right-handed Z-up
   7741   1   1
Hello!
I have a rotation matrix that is from a right-handed Z-up coordinate system. I am having no luck converting it into rotation angles that are usable in Houdini via Python.
What I need to know is how to convert the Matrix3 to left-handed Y-up (what I believe Houdini uses).
I'm thinking that after that I should transpose the matrix, convert it to Quaternion, then use extractEulerRotates() to get my rotation angles. Is that also correct?
When I try to reverse engineer the process by converting a scene object's Euler rotations into Quaternion and then into a rotation matrix, only the first rotate matches my initial matrix. I'm not sure where the other two columns are coming from…
Any ideas? Thanks in advance!
Windows 7 64-bit, GeForce GTX 260, 12 GB RAM
OK, after a lot of battling I have it working like this:
zup = zUpMatrix
zup = z.transposed()
toYup = hou.Matrix3(((1, 0, 0), (0, 0, 1), (0, -1, 0)))
yup = toYup * zup
yup = instRotation.transposed()
q = hou.Quaternion()
q.setToRotationMatrix(yup)
rotateAngles = q.extractEulerRotates()
Basically the part I was missing was transposing it TWICE. Oh – and Houdini is Y-up right handed, not left-handed as I thought earlier.
