Add Polygon face or such
   7414   3   0
How can I connect 2 edges with a polygon face? If you have ever used softimage , the N key does just that.
This is what I'm trying to do:
I want to connect those edges to make 1 solid piece with hole.
I hope I explained well!!
Thanks for help
hi ,
if you want to ‘cover’ all at once with a single poly use “Polycap” .
( but judging from the pic i doubt if thats what you want since the poly will be not coplanar . )
if you want to ‘draw’ polys following your mesh flow , id suggest to use “Polyknit” .
once you call that , start selecting points over the mesh and finally , press enter .
do some tentatives first in order to understand how it wants the points ‘served’ ..
there is visual feedback too .
except the things that cannot be seen , nothing is like it seems .
Hah that does exactly what I wanted to do !
Thanks a lot!
Try this instead http://vimeo.com/23793987 [vimeo.com]
