if i create a new object type and its parameters as well, then i want to add an event handler for this parameter, so if the parameter is modified/changed this handler will call a function.
kind like –> onchange().
the goal is to make a filter , so if someone change the value too high , it will be automatically cut down to max value allowed. it's similar to ‘clamp’, but this time i hope i can make a ‘realtime’ filter.
is it possible or not?
clay~
