Target Fuse in Houdini?
   4259   3   1
I am looking for a tool where one vertex will fuse/weld to another but without their position being centered, but using the position of either one (always first or second).
How can I do this in Houdini?
Uncheck the fuse distance and grab the first point than the others…
The first will be the traget. You can also type them manually. Look at the PT order in the fuse group!
Save it as a permanent default to auotmate it!
Hope that helps!
Thanks, I didn't notice the checkbox, I will try it when I get home.
Cheers.
Thanks man, it works great.
