point indices in prim (hscript)
   6899   14   1
Hi All
This is probably a very simple one.
How do I get a list of point indices in a prim using hscript ?
http://www.sidefx.com/docs/houdini11.1/expressions/pointlist [sidefx.com]
Drive, monkey, drive!
pointlist(surface_node, group_name)
are you sure this is not to get the list of points in a group.
i would expect to be able input the prim index
ie
pointlist(surface_node, prim_index)
Yeah. I missread the question. Thought it was for the whole object for some reason. No idea how to do this with hscript but you can do it by combining some python expressions.
I'm quite new to this.
so I would appreciate an example if possible.
Also how do I :
get a prim count in a mesh
get a vertex count in a prim
At the moment I need to use Hscript.
http://www.sidefx.com/docs/houdini11.1/expressions/nprims [sidefx.com]
Returns primcount in mesh. Second i don't know in hscript.
rom12345
Also how do I :
hi ,
i don't know why you insist about Hscript , but here you have a Pythonic otl :
this creates a string attribute containing the points of each prim .
controls are minimal ; assign values to only one / to all prims .
optionally( im not sure though )you can execute this python code as a script using Hscript's execute command .
never tried that myself ..
hasPoints_py.otl (3.1 KB)
except the things that cannot be seen , nothing is like it seems .
many thanx for this.
This thread
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=23623 [sidefx.com]
will explain why I need to use hscript for now.
Hey zarti
I have tried out your otl.
The attribute “has_points” is created ok
I figured I would get a string out
but when I try to query it in the textport I get :
echo `prim(“/obj/box”,2,has_points,0)`
2
attribute should be inside double quotes ..
> "has_points"
Edited by - Oct. 29, 2011 20:05:19
I tried that, but I'm getting the same result
I tried to do a quick test by modifying your code
prim.setAttribValue(hasPoints_attri,“hello”
but i still get :
echo `prim(“/obj/box”,2,“has_points”,0)`
0
double post
try this ..
/ -> echo `primsmap(“/obj/geo1/hasPoints_py1”, “has_points”, 0)`
1-5-4-0
That's great
I really appreciate this
many thanks.
