render curve in rman
   3968   1   0
I created a curve in houdini by using the curve sop. I generated a rib file but I could not find the curve command on the rib file. So i still could not render that curve with renderman. Does any one know how to render curve in Houdini with renderman renderer?
thanks
Throw down an attribCreate after the curve.
Add a point attribute with a type of float, call it “width”.
give it a value of 1.
after the attribCreate throw down an attribute sop.
under the renderman tab enter the following:
Houdini RiName: width RiType:width
with a type of varying float
that should do the trick
