need help for chop: keep value
   3250   4   0
here are two channels, named source and reference, i want the source channel keep changing value if the reference channel is upper than 0,
and keep value if the reference is below 0.
attached jpg shows what i want
how can i do this?
https://vimeo.com/user3971456/videos [vimeo.com]
The Hold CHOP does exactly what you want. You'll need to separate the channels, feed the one you want to hold into input #1, and the reference channel into input #2.
twod
thank you Twod, I've tried hold, it seems hold values to minimum and maximum, like some kind of clamp.
i think i need hold when the reference is below 0 only, am i set the Hold wrong? or need any more after Hold?
I believe icmin and icmax work on a channel you can find the min and max and extract the values out into sops as an attribute.
rob
Gone fishing
you can use Expression CHOP, the first input of expression chop is your reference curve, and the second input is the source, and then in the Expression 1 field, typing the expression:if(ic(0,0,$I)>0, ic(1,0,$I), oc(0, $I-1)). I think this is what you want.
Houdini is a big thing!
