I feel kind of stupid for asking this because I expected it to be really easy, but how would I get lets say all “Texture” VEX nodes in the whole script via python?
Cheers
Sebastian
python - filter nodes by type
14632 6 1-
- SElsner
- 23 posts
- Erik_JE
- 300 posts
- graham
- 1926 posts
- SElsner
- 23 posts
Thanks graham, works beautifully.
Investigating further this is not what I wanted.
Actually I am trying to get a list of all images used in the current houdini file. The approach with just getting the texture nodes does not work because the map parm might be connected to a parameter node (promoted) so the map parm does not update. I have been looking into this but could not find out how. How do I find all images in a session in a general way (not just for mantrasurfaces, but for all textures used)?
obviously what I have been doing for maya and nuke a thousand times works in a completely different way in houdini….
Actually I am trying to get a list of all images used in the current houdini file. The approach with just getting the texture nodes does not work because the map parm might be connected to a parameter node (promoted) so the map parm does not update. I have been looking into this but could not find out how. How do I find all images in a session in a general way (not just for mantrasurfaces, but for all textures used)?obviously what I have been doing for maya and nuke a thousand times works in a completely different way in houdini….
- graham
- 1926 posts
Take a look at the hscript ‘opextern’ command.
You could also use the getExternalReferences() function in this module, as it is just a wrapper around opextern.
http://houdinitoolbox.com/houdini.php?asset=38 [houdinitoolbox.com]
- SElsner
- 23 posts
- Netvudu
- 304 posts
