Any way of moving the pivot without the object moving?
38465 11 2-
- thexon
- 88 posts
Man i really must be missing sumthing,whenever i move the pivot(insert) on an object that doesnt have zero rotate/translate,…the object moves too….in maya and carrara(and after effects),when in pivot mode your efforts affect only the pivot…….consider trying to animate an object that needs an animated pivot point….e.g…..a box rolling(without using dops)…..the " option wont give u accurate rotations also
the xon can
- circusmonkey
- 2624 posts
- thexon
- 88 posts
- sl0throp
- 258 posts
- thexon
- 88 posts
- adrianlazar
- 102 posts
- thexon
- 88 posts
Sigh…..sorry ,i probably should attach some pix to show what the problem is….. “ ” " doesnt really move the pivot…..it just moves the manipulator….this becomes apparent when you…..say,move the manipulator to a door hinge,….keyframe………..go to frame 24,rotate to open the door……scrub through and you will find that your object rotaes around its centre and not the manipulator
the xon can
- sl0throp
- 258 posts
Why not just parent the object to a null and rotate that so you can handle it at the obj level. Personally unless I need to, I avoid object level transformations. I would handle this within sops and if I wanted to animate at the top level i would do it through channel referencing that would reference some transform in my network.
In Maya I would handle this by parenting my geo to a locator where I would want the pivot rather than moving the pivot itself. While functional, having unseen pivots seems undesirable to me in this context.
- thexon
- 88 posts
Say u want a box to roll twice,youl have to move the pivot to one edge,rotate……..move the pivot again,and rotate again,right?….in maya this shudnt stressyou……but in houdini….attempting to move the pivot afteryou have already translated or rotated the box…..will result in the box moving weirdly(yes ,even in pivot mode,(insert))…hence making it impossible to animate an object that will need the pivot to move……..im sure there is a way,to do this,im just such a noob
the xon can
- thexon
- 88 posts
- Jason Harmon2
- 1 posts
Found this thread looking for some answers. Wasn't helpful for my situation, but I did find something that might be helpful for anyone who stumbles through here. If you have a transform SOP that you just want to rotate the pivot in order to re-orient your axis for animation… right click on the transform handle, un check the option for “attach to geometry” rotate your handle, then re check that box. The alignment of the transform SOP should be as you want it. At least it worked in my situation.
- brandony
- 1 posts
